PoolSan
Regenerator
For regeneration of PoolSan & shock dosing of pool water
- Treats
cloudy or green water and leaves your pool sparkling and clear.
- PoolSan
Regenerator dissolves rapidly to break down pollutants in the water
such as bather waste.
- Use
PoolSan Regenerator at the first sign of cloudy or green water.
- It
helps to restore the activity of PoolSan Chlorine Free pool treatment
so that it works to best effect as a pool sanitizer breaking down organic
matter.
Instructions
- PoolSan Regenerator can be dosed directly into the pool water.
It should be used when bathing has ceased, bathing can resume 15 minutes
after application.
- Calculate the volume of water in your pool.
- The dose rate is 200g
of PoolSan Regenerator to 10,000 litres (2,200 imperial gallons) of
pool water.
- Dose into the pool where there is good water movement, or
evenly over the surface of the water.
- Use once a week when pool is in
use or once every four weeks when the pool is not in use.
- High volume
bather pools, commercial, may need to treat with PoolSan Regenerator
more frequently. This can be checked by testing oxygen levels, that
should be between 3.0 – 8.0 mg/l (ppm) using appropriate
tester.
- If the pool water is cloudy or looks green on inspection, dose
the pool with 200g of PoolSan Regenerator per 10,000 litres of pool
water.
PoolSan Regenerator volumes
25,000 litres
= initial dose 500g
30,000 litres = initial
dose 600g
50,000 litres = initial dose 1
kg
90,000 litres = initial dose 1.8 kg
120,000 litres = initial dose 2.4 kg
150,000 litres = initial dose 3 kg
300,000 litres = initial dose 6 kg
Dosage levels are only a guide. Regularly test pool water.
